BAK 1162426 16-17 TACOMA ACCESS CAB AND DOUBLE CAB WITH TRACK SYSTEM WITH BAKFLIP VP TONNEAU COVER 5 FT.
BakFlip VP Folding Tonneau Cover (1162426) by BAK. Material: Vinyl. Finish: Black Vinyl (Marine Grade). This impact-resistant tonneau cover is the newest addition to the BakFlip bed cover family and it's also the most affordable hard cover on the company's list. The one-piece BakFlip VP has a low-profile design which ensures maximum visibility for the driver. The cover easily operates from either side of the truck which translates into easy access to the tonneau.
Features- 16-17 Tacoma Access Cab & Double Cab with Track System with Bakflip VP Tonneau Cover 5 ft.
- Textured vinyl over insulated heavy-duty aluminum panels
- New self-contained buckle system secures cover in folded position
- Sleek no-profile design
- Lightweight construction
- Aluminum panels can be locked even in the fully open position
- Special rubber bumpers and panel frames ensure full cab protection
- Scuff and ding resistant vinyl top surface
- Side seals of EPDM rubber
- Hinge-less one-piece look; no visible seams
- Automatic latching
- 100% truck bed access
- Easy No-drill clamp-on installation
Price: 1293.85
