BAK 226409 07-17 TUNDRA CREW MAX WITHOUT TRACK SYSTEM WITH BAKFLIP G2 TONNEAU COVER 5 FT. X 6 IN.
BakFlip G2 Folding Tonneau Cover (226409) by BAK. Material: Aluminum skin with EPS standard solid core. Finish: Semi Gloss Black. The BakFlip G2 Folding Tonneau Cover core is laminated from impact resistant fiber reinforced expandable polystyrene with a surface in aluminum. The patented rubber hinges are absolutely watertight and water from the top of the cover is drained through channels and drain hoses to keep the truck bed dry under any weather conditions.
Features- 07-17 Tundra Crew Max without Track System with Bakflip G2 Tonneau Cover 5 ft. x 6 in.
- Folding panels combine the strength of a solid panel cover with the flexibility of a roll-up cover
- Premium UV resistance won’t fade or chalk
- Weather resistant
- Drive with the cover closed fully or partially open
- Lightweight panels are easy to operate
- Sleek low-profile design
- Cover allows full access to stake pockets
- Panel core made in super strong and light fiber reinforced expandable polystyrene
- Panel frames in aluminum or aircraft grade aluminum
- Panel exterior in aluminum
- Patented watertight full-length EPDM rubber hinges
- Efficient draining system integrated in the rails keeps bed dry in all weathers
- 3rd brake light visibility complies with Federal safety standards
- Secure locking mechanisms easily handled from both sides of bed
- Intermittent locking positions
- Secure locking of folded up cover
Specifications
Price: 1146.93
