BAK 448409 07-17 TUNDRA CREW MAX WITHOUT TRACK SYSTEM WITH BAKFLIP MX4 TONNEAU COVER 5 FT. X 6 IN.
BakFlip MX4 Premium Folding Tonneau Cover (448409) by BAK. Material: Aluminum skin with EPS premium solid core. Finish: Matte Black. Add a little extra style to your truck's decor and safeguard your truck bed against dirt grime rain and snow with this premium grade aluminum hard folding cover. The BakFlip with a sleek no-profile flush mount design features a superior flat matte black texture with the highest possible UV and scratch protection and an enhanced tailgate seal which allows the truck lid to be closed whether the tailgate is in the closed or open position.
Features- 07-17 Tundra Crew Max without Track System with Bakflip MX4 Tonneau Cover 5 ft. x 6 in.
- Flat matte black texture perfectly complements your factory black trim
- Premium grade heavy-duty aluminum panels deliver advanced UV and scratch resistance
- Superior rear seal allows the cover to be closed with the tailgate in the closed or open position
- Premium density foam core provide superior resistance to moisture and decay
- Injection-molded latch housing for long-term durability
- Integrated buckle system allows to secure the cover in the folded flipped or closed position
- Rated up to 300 lb of evenly distributed weight
- Provides full access to truck bed and stake hole pockets
Price: 1477.20
