BAK INDUSTRIES 226506 05-16 FRONTIER CREW CAB WITH OR WITHOUT TRACK SYSTEM 5 FT. BAKFLIP G2 TONNEAU COVER
BakFlip G2 Folding Tonneau Cover (226506) by BAK. Material: Aluminum skin with EPS standard solid core. Finish: Semi Gloss Black. The BakFlip G2 Folding Tonneau Cover core is laminated from impact resistant fiber reinforced expandable polystyrene with a surface in aluminum. The patented rubber hinges are absolutely watertight and water from the top of the cover is drained through channels and drain hoses to keep the truck bed dry under any weather conditions.
Features- Folding panels combine the strength of a solid panel cover with the flexibility of a roll-up cover
- Premium UV resistance won't fade or chalk
- Weather resistant
- Drive with the cover closed fully or partially open
- Lightweight panels are easy to operate
- Sleek low-profile design
- Cover allows full access to stake pockets
- Panel core made in super strong and light fiber reinforced expandable polystyrene
- Panel frames in aluminum or aircraft grade aluminum
- Panel exterior in aluminum
Price: 1146.92
