RETRAX RTX80501 PRO MX TONNEAU COVERS FOR 2006-2014 RIDGELINE WITHOUT PASSENGER SIDE LOCK
Features- Heavy-duty aluminum construction
- Textured matte powder coat finish
- Tough textured finish deters scratching
- Supports distributed loads of up to 500+ lbs
- Front cover remains flush with rolling cover
- Low profile design
- Opens and closes easily with one hand
- Sealed ball-bearing roller design
- No pull straps cloth hook and eye snaps or springs
- Enhances aerodynamics to improve fuel economy 7-2010 % in the closed position
- Standard with lock cylinder and key for security
- Key lockable in any position
- Secures your valuable cargo
Compatibility- 2006-2014 Ridgeline without Passenger Side Lock
Specifications
Price: 2547.96
